configure ports forward-error-correction
configure ports port_list forward-error-correction [off | on [cl74 | cl91]]
Description
Enables/disables IEEE Forward Error Correction (FEC) Clause 74 or 91 modes.
Syntax Description
port_list List of ports to enable/disable FEC modes on.
forward-error-correction Configures port FEC mode.
off Disables all FEC modes (default).
on Enables FEC modes.
c174 Enables/disables FEC IEEE Clause 74.
c191 Enables/disables FEC IEEE Clause 91.
Default
FEC is not enabled by default.
Usage Guidelines
This command allows you to enable/disable Clause 91 or Clause 74 (exclusively) on a per-port basis regardless of speed/type.
FEC gives the receiver the ability to correct errors without requiring a reverse channel to request retransmission of data, but at the cost of a fixed, higher forward channel bandwidth. Some devices require this to interoperate.
The following example enables FEC Clause 91 on port 1:
# configure ports 1 forward-error-correction on cl91
The following example turns off FEC on port 1:
# configure ports 1 forward-error-correction off
This command was first available in ExtremeXOS 22.3.
Platform Availability
